Turbo? ( cost ? )
OLLY
23 Jan 2012
Hola
Which type of turbo can i fit to my UMM Alter2 2.5TD.
Also is there a place on the turbo i have fitted to see what the psi reading is?
obrigado
Olly
I think that is KKK16, but you can use Garret (for hiways) or anyother car that use this engine (Ford Scorpio 2.5TD with engine SFA or SFB , peugeot 505TD, 604TD etc ..). I made a t conection on the tube that join the turbo to the diesel pump.
OLLY
23 Jan 2012
Gracias amigoa:)
That will make it easy to find one as i see there is a lot of cars to choose from now.
Which type of Garret can i use as i see there a lot.
Olly:)
OLLY
23 Jan 2012
I need to see if this is the same a smine, it is but slight differences.
the one on my UMM
One i found
Both are KKK but not sure if mine is the K16 as the one is i found and a code after it saying 2015A
the part i am stuck on is the finned/cooling part.
Its not easy to see or gte when fitted(n)
OLLY
23 Jan 2012
I removed the turbo the other day, filled with plenty of lube and its all ok now, spins nice and free and no play in the shaft:D, i need a new compressor O ring which i am looking for but then its back on with it.
BUT i did snap of the banjo nut on the middle inlet manifold, so i hope i can get an extractor in to remove the rest.
Olly
Olly,
the turbo charger unit you have on the pic aint the same thing.
Here are the exact references for the UMM Alter turbo unit:
K16
92 382 0776
53169706702
have a look at this topic for details and more pics
https://for-umm.pt/oldthreads/19229
There is a particular wastegate on UMM Alter Turbo, among other details.
Its not easy to find this turbocharger unit as a "straight fit" as ppl say.
sorry for not being able to answer your other questions you made so far.
P.S. HOLA = Hello / Hi in Spanish...in Portuguese "drop" the "H" :p
Speak soon
Carlos
OLLY
23 Jan 2012
Hi Carlos, thats a nice clean one you have/had there, i have got my original turbo running nice now and refitted to try, i am just finding it hard to find the banjo bolt i broke off, i removed the stud that was stuck in the head, but as it is a 8x1.25 banjo bolt hard to find a replacement, i have one on its way but it is a little shorter, i can only see if it fits.
I have tryed all peugeot 505/506 ,Granada scorpio, ldv 400 etc etc:disappointed_relieved:
I dont know if you have seen the LWB green UMM that was on ebay, my mate won it, we have a 500 mile round trip next week to collect it:D
OLLY
23 Jan 2012
My turbo is a dead:angry:
So to rebuild it will cost near £400.
I cant find one in the UK second hand
How much do they sell for in Portugal?
Could anyone send me one over please:D
I am thinking n about fitting another engine if its going to cost so much to replace, only for more power as i will be pulling a small boat also have the camper on the back.
regards
Olly
your turbo it seems a kkk with a garrett exhaust flange...maybe the garrett t3 turbos fit in your umm,in that case its more easy to find a used one(iveco 35.12 have...)
OLLY
23 Jan 2012
This is my turbo
I have found a Audi 100 is very much the same, this is the one i found
but the manifold is different as in the Audi is 4 bolt fitting and the UMM is 3 bolt. And the Audi turbo has the fuel pipe to the actuator, but i think i can block this off.
I have the idea i can make an adaptor to fit in the middle of the Audi turbo and the UMM manifold by using captive bolts in the adaptor.
