transmission trouble...
hi@all!
which transmission fits a 1983 cournil?
i´ve now looked what´s wrong with mine and found the main bearing broken.
i´ve put in a new one 6307,because all other stuff looked o.k.-exept the wheel for 1. and 2. second gear
even the shift-fork shows some damages...so i can pull in first and second gear,but as soon as i release the clutch,the gear popps out...
how to find any parts?
thank you!
I don't know how help you, is too much for my english...(n)
I think you need a "anilha sincronizadora" (washer Synchronize?). Where you can find it in Germany? I don´t know...(n)
Tell us which transmission you have will help. ZF or UGO?
there´s something like ugo written on it...it looks quite similar with the jeep t98a,as i found out...
the only gears working are the 3th and the reverse.
i´m afraid i need more stuff...
If the reverse it's on left (side of 1 gear) is ZF. If the reverse is on the ritgh (side of 3 gear) it's UGO.
I allready read something about our transmission be very similar like one jeep, but I don't know...
I just send you a email with 2 documents.
