OLLY
Hi all, my firdt tech Q if thats ok
I am getting my 1992 UMM ready for the road, i have near fixed the lights, a few bulbs and bad earth, easy fix.
Now i found that the screen wipers did not work, after messing around i noticed that the black (earth) wire from the motor connection to connector block stopped there and did not pass through the block.
Once i earthed the black wire from the motor to the body it all worked fine, has the black wire from the connector block been removed you think.
I need to check before i add a connector to the block and earth the motor.
Oh and what is fuse 5 for, now and then it keeps blowing?
Thanks Olly
Thanks Olly
