Jim Carroll
Hi All,
I have a lot of vibration in my 1986 Alter 1 from 60 - 90 kmph. I started to grease all the joints on the shafts and I have found the front stub axles have a lot of movement in them.
I took the front end apart and got the spindle off, I found the needle bearings inside are broken. I am hoping that this is where the vibration is coming from.
The joints in the front stub axle (Cruzetes?) do not have a grease nipple on, is this normal? Should I replace them for a part with a grease nipple on? I also have kick back through the steering wheel on full lock in 4x4 mode.
I need to get new needle bearings for the spindle, does anyone know the reference number and anywhere I can get them in the Algarve? I think I really need a full kit with seals and there is a bronze bush in there as well? Mine has gone if there was one there!
Thanks Jim
Thanks Jim
