cheap new disc?
Jim Carroll
25 Set 2010
Hello everyone, sorry for writing in English. If this is useful hopefully someone will translate for me.
I have been looking at options for front brake discs for the UMM. I have found that the brake discs for a KIA Sportage are nearly the same size. There is 1mm difference in overall height, that would be easily taken up by the movement in the caliper. They are also slightly thicker, 24 mm instead of 20mm but the volvo brake discs are also 24mm thick and they use the same caliper so that should be OK. The only problem may be with the centre hole, if this is too small it would be worth getting them machined out.
The price for the new KIA discs are €80
http://www.ebcbrakesdirect.com/car/parts_disc.asp?part=disc&make=KIA&model=Sportage&year=2%2E0+%2899%2D2004%29
for comparison of size
http://www.euro4x4parts.com/parts/bdi1398-5001_front_brake_disc_pair.html
I have a friend I will contact to get all the sizes of the KIA discs to make sure we can use them. Jim
Tank you, Jim i go check the information.
È mole mas sobe.
rjoina
18 Fev 2011
Tanks a lot Jin, very good information. ;)
Aveiras de Cima a concelho
Jim Carroll
25 Set 2010
Hi Mário, I have spoken to one of the manufacturers of these discs. The hole size in the Kia discs is 12.8mm. It is not perfect because we will have to make to holes larger with a drill, but it is better to have holes too small than too big! I asked today for a price for these discs from a local car parts shop. They want €140 for a pair. I have an Alter 1 with the old brakes and I have all the parts to change my UMM to disc brakes but the discs I have are too thin to use. When I have everything ready to fit them, I will let everyone know if it works. I have to get a service kit for the calipers from somewhere and the new discs from the UK. Maybe in two or three weeks.
markilhas
29 Abr 2006
jim thanks , to see if they can be a disc to the Umm, my brother have buy a new pair of disc and it's a way too put the UMM brakes funccional..thanks and regards
UMM Cournil 80
UMM Alter 1 87
UMM PornStar 80
Hi Jim,
Again,
How's it going?
Found the right discs?
Any progress?
I suppose there is out there in the market the correct disc size, and a straight fit.
I reckon we are all a bit lazy in finding the correct information.(Me included)
See what can you find on ebay.co.uk
I will tomorrow dig some info I have on my puter as compatible parts.
Keep the topic informed and good luck.
Carlos
Jim Carroll
25 Set 2010
Hi Everyone,
I am still waiting for other parts for my UMM before I start all the work. I have a lot of work to do to it in the winter! I need to have a set of umm discs that are OK in case the KIA discs do not work, I have found the KIA discs for €70 euros now.
bizarro
13 Dez 2010
Medidas detalhadas dos discos para KIA Sportage.
PReço do par via oscaro: 70€
bizarro
13 Dez 2010
:D:D
Também tenho aqui um par de discos originais UMM usados na mesinha de cabeceira para começar a tirar medidas.. ;)
ajoaovm
30 Abr 2006
Boas Jorge, ja tive os dois a par e as diferenças são:
-furo central Kia maior
-espessura disco Kia maior
-espessura da falange de aperto Kia menor
-afastamento falange/disco igual
-furos menor diametro
Pessoalmento considero uma solução, nem que tenha de levar uma bolacha para calçar a diferença de espessuras da falange central.
António João
Serralhariaajoao4x4team
JummP
9 Jan 2007
boas António João
e a espessura do disco ser maior não é impeditivo? não vai ficar desmasiado justo aos calços?
estás a pensar experimentar? se sim depois diz alguma coisa
também estou a precisar de colocar discos novos e se esses forem opção, sempre se poupam uns trocos para outras peças;)
Delgado
20 Out 2008
Olá António João!
A furação dos pernes bate certa com as furação do UMM, além de serem de diâmetros diferentes?
Abraço,
Delgado
